I need to make the peddle travel longer as from idle to WOT is around 1" of peddle movment
Was thinking along the lines of introducing a bell crank at around a 2:1 ratio, maybe slightly less. Anyone got any other ideas?
cheers
Floor mounted or high-mounted?
Can you not just move the cable further from the pivot point?
high mounted.
Unfortunatly not. where it would ideally go is a mounting point for the peddle box. If I move it to the other side of this then it is very close to
the rear M/C bellows and pushrod and I figure Mr. SVA might not like that very much.
Also dont I want to move it closer to the pivot point? Cant do that because of the aforementioned!
[Edited on 8/5/08 by iiyama]
Sorry, stupid moment. yes, you need to move it closer to the pivot.
Got a pic, so we can see the problem? Where are you thinking of adding the bell crank?
How about adding a bellcrank? You could easliy change the cable movement ratio that way...
what about changing the size of the pulley/lever on the throttle body/carb to adjust your pedal to throttle movement?
I'd put a bell crank in.
Whats WOT?
adrian
wide open throttle ? maybe
Yes indeed, WOT is wide open throttle.
Ill take some pics and post em up in an hour or so.
Would be happy to change the lever/pulley on the throttle bodies as that would be a much simpler solution then adding a bellcrank into the line.
OK, pics!
Movement strangly looks a lot more in the pics then in actually is!!!
This is where I was thinking of mounting a bellcrank ie where the throttle cable is supported.....
[Edited on 9/5/08 by iiyama]
I post art and you all run away!!! Something I said? LOL
