hi all
trying to start r1 5vy
fuel pump not working and following codes 14/23/30
anyone know what they are or where to find them in service manual
thanks andy
tried that,no brum
do you need to to reset the clocks and if so how?
yes still scrolls the 3 codes
reset the mcu....
and see if they come back...
if they do you know what to solve..
its an easy one..
Tks
hi,tried tilt sensor in every posistion and code still there.will try direct wire to pump tomorrow.
what an mcu and how do i reset it
thanks for that ,i'll give it a go
mal at yorkshire engines supplied the loom and ecu so should be ok.will let you know how we get on
when i had cod 30 on mine i had to put the tilt sensor the correct way up, then turn the ignition off, and back on.. the code would then go
I had to do the same as ^^^^^^^too
[Edited on 10/5/08 by CRAIGR]
The tilt sensor is latching so won't reset until you switch the ignition off and back on again.
