Went out for a run with the NE7ER's this morning. Managed about 35 miles before my clutch cable snapped, again
Managed to get going again, but the clutch was dragging when the pedal was fully in, so although the open roads were fine, through villages etc was a
pain. So I bottled it and limped home.
My ZZR1100 engine has a hydraulic clutch as standard, which I am operating using the original hand clutch lever / reservoir, which is in turn
connected to the pedal by a cable. It's this cable that has snapped, on several occasions now.
So I'm investigating changing to a hydraulic master cylinder fixed to the bulkhead, operated by a traditional push rod instead.
It'll mean a bit of modification to the fire wall, but it should be OK.
So, does anyone know how I can find out the size of my existing cylinder? and or what size I need for my new one?
I'm thinking of going for the Wilwood Ally Master Cylinder with Integral Reservior, unless anyone has any bad experiences of them!?
It's available in 0.625", 0.700", 0.750" and 0.813" bore.
Mike
Excellent choice but you could also use a Girling jobbie withg or without remote reservoir as access allows.
I think you will need one of the smaller sizes. My Duratec uses a .75" bore which is perfect for my clutch but the Kwacker might need something
more petite like a 0.625" - the only real difference being the throw required to disengage.
If the cable is snapping odds are you need to restrict the pedal movement with an adjustable stop.
Thanks Razman, I think I'll try the smallest size first.
BT, the cable isn't being stretched, it's rubbing on a sharp edge on the bulkhead as it leaves the pedal and goes through the tube (that is
welded in at an angle).
I've tried filing it down, but it doesn't seem to make any difference
There isn't much room down there to get at it all!
Mike
bike master cylinders often have the bore size cast into the body, but if not it should be easy enough to remove the piston and measure it.
have you not considered using the existing bike master cylinder with a rod operation?
Al.
I used the .625" on my ZX10 Mike, I would go for that but watch out for the amount of stroke. I had to limit mine to stop it turning the clutch
inside out.
Steve.
Originally posted by stevec
I used the .625" on my ZX10 Mike, I would go for that but watch out for the amount of stroke. I had to limit mine to stop it turning the clutch inside out.
Steve.
To operate your clutch you could use a motorbike rear brake master cylinder which would operate in vertical or horizontal orientation and has a remote reservoir attached to it.
Andy Bates knocked me up a very neat little bracket to hold the master cylinder, now no longer needed if you interested
Yep, what PeteFF said. The one you're using at the moment will probably be 1/2" (it will be cast on the side) and most bike rear master
cylinders are that size.
Have a search on eSkip....
Steve.
Thanks Steve! 0.625" it is.
So if I mount it as low as possible, so the pedal travels the full distance to the bulkhead, but the push rod is close to the pivot point to limit its travel?
Mike
