I think I have most of my R1 leccy sorted (until I try and start her that is !!!) but I have a query on the earth cable.
There is an black offshout cable from the engine earth that has a single connection and I cant seem to find it on the R1 electric diagram - what
should it be connected to ?
hope I have explained this correctly as the batteries in my camera have died so cant provide a pic at the mo
in case it makes a difference the engine is 03
[Edited on 26/5/08 by markyb]
Pic?
Is that the smaller one that goes from the battery along with the main earth cable?
Joao
here is the connection I was talking about (the one with the white shroud)
After having another look at my loom I think I found where it should be connected to but just want to check. There is a single black cable that
emerges from the loom just before the ECU - is this correct one to use ?
EDIT : Havent posted a pic before so must have got it wrong somewhere - the pic is in my archive
[Edited on 27/5/08 by markyb]
that connector then hooks into the earthing loom I think as the bike doesnt eath to the chassie everything is supplied via one cable
thanks - found the connector hiding in my loom eventually but always worth a double check
