zx12r clutch cable
eddbaz - 6/6/08 at 05:12 PM
Is there anywhere I can get a clutch inner cable with a nipple on the end (pear type) that is held captive in the zx12r engine clutch lever, the one that I got with my cable kit has a barrel type end that secures to the cable with a small screw which isn't held captive in the lever and can come out,also I could do with a longer cable,the outer and the peddel end are o.k.
Also will the return spring on the engine clutch lever be strong enough to return the pedal.
[Edited on 6/6/08 by eddbaz]
[Edited on 7/6/08 by eddbaz]
