Can i sit at my pc and download a map onto the usb power commander when its not connected to the car using the 9v battery that comes with it.???
Can't go in the garage and do it as my laptop battery has died
[Edited on 14/7/08 by CRAIGR]
Certainly can, just use the adapter and the 9v battery you mention.
Just make sure its a nice new battery!
Then install the accelerator pump software and have a play with that!!
Cheers Charlie
Or fit the lcd power commander screen and do it on the sd card......bit expense that way though!
