so where did you people get yours from 03 R1 recomendations please
If you are recommended the pipercross one then I have a new one here for a locost price but you will need a backplate.
Sausage shop.....
no seriously Pipercross in Northampton
Mark
Jason you have a u2u
Barry
one quick bit of advice, well two, if your remotely considering a track day at any time then dont go the sausage route, noise will be an issue, two, I imho dont rate them unless you fit something a bit deeper than the average , 100mm min, buts just an opinion......
You need to ensure at least a 25mm air gap between the top of the trumpets and the internal part of the foam, whatever type you're ordering.
We used to sell a lot of the ITG ones (they make filters for a lot of the F1 teams).
well the std air box dont fit by about 3 inches and yes im planing on maybe 1 trackday a year but i like the look of a sausage type filter does anyone reccomend a company that does the back plate pre drilled to fit
mnr do a back plate and filter combo
Just get a blank back plate and use the airbox you have as a template.
Jason
