What sort of fuel economy do you get from a powerful BEC.
Iv heard figures around the 15 - 20 mark.
My god is that all.
i only get 15 - 20 from my tcec
MPG - is that miles per gearbox?
Originally posted by madteg
My god is that all.
Who cares?
I'm getting 25+ on the road with plenty of right foot. Was about 10 on the track.
adrian
dont compare BEC MPG to a tintop on the road, compare it to something that can keep up - supercar mile per gallon is a lot less than 10mpg on
track.
If you are pootling expect to get more like 30-40 mpg, but not much point pootling in a bec mind - kind of misses the point.
i can't get BEC type mpg out of a 1600 pinto however i drive it.
the head design is far superior to any standard car engines and with it comes better efficiency.
tom
anywhere between 10 and 40, dependant on the amount of lead content the shoes your wearing have in them
6.61MPG (Radical ZX14 on sprint track)
[Edited on 31/7/08 by minitici]
Keeping off the Mways helps as the temptation to go above NSL comes in and the (non)aero qualities of a seven really hit the MPG.
Strangely I get
better MPG on a good back lane hoon than on the 12 mile jurney down the A3 to work - too tempting to keep up with the outside lane...
Strangely I get better MPG on a good back lane hoon than on the 12 mile jurney down the A3 to work - too tempting to keep up with the outside lane...
Cheers Ray
my 98 R1 BEC returns about 30 MPG in normal road use (full throttle to the red line wherever possible). A long A-road run sees over 35 MPG wheras on the track I get 20 - 25 MPG. Obviously, on the track I drive much faster than is possible on the road.
Originally posted by Dangle_kt
dont compare BEC MPG to a tintop on the road, compare it to something that can keep up - supercar mile per gallon is a lot less than 10mpg on track.
Think I might need a better ratio diff for mine
8200 rpm at 80 isnt helping - or is that about average?
Sounds about average, I get 10mph per 1000rpm in 6th gear with the ZX9R
Ian
Originally posted by hobzy
Think I might need a better ratio diff for mine8200 rpm at 80 isnt helping - or is that about average?
I have 2003 R1 and 3.62 LSD, what can i expect at 70 on the motorway bumbling along>
Hmm. Must get my backside under and find out what diff it is...Cheers.
Ian
Don't know and don't really care I'm usually having so much fun
If it needs fuel just fill it up and off you go and play again
Sorry not much help am i
