i just fitted my r1 airbox cant afford £100 ish for a sausage filter and when i opened the airbox weather malc knew or not sat a brand new
K&N filter
has anyone any concerns over my mods to fit the box re. the opening
hole
Are you going to cover it up, then it would perform as Yamaha intended.
Originally posted by roadrunner
Are you going to cover it up, then it would perform as Yamaha intended.![]()
The air is fed into the centre of the filter through two tubes moulded into the lid of the box. With a big hole like that, the air will get into the
box but not through the filter. Not just air but grit and leaves and water and stones and small children and soil and all sorts of things. You need
to close the hole.
The box will be smaller which will affect the torque curve a bit but you should be OK.
Originally posted by smart51
The air is fed into the centre of the filter through two tubes moulded into the lid of the box. With a big hole like that, the air will get into the box but not through the filter.
