Just had the rear of my indy up on the jack and noticed a good 1/2 inch of play when pulling wheel left &right,seems to be wear in the lower wishbone bushes nearest the wheel-any idea guys were I can get these bushes ? Thanks - Keith.
If they are the standard Poly Bush various places, Ebay, Rally Design, 3GE Components
MK? Might take 6 weeks, and three attempts at getting you the right ones though!
Hi
Might be worth confirming that you havn't got 12mm bolts in 1/2" brackets / bushes - also that the bolts are torqued up onto the crush
tubes.
Regards Mick
