oops bent it - help
Murphy - 29/4/12 at 09:15 PM
think i have escort or cortina front and bent my track rod arm (pebble)
Can it be bent straight?
If not where best to get these.
Thanks all
austin man - 29/4/12 at 09:25 PM
Probably be able to pick a new one up from Rally spares etc personally I wouldn't straighten it as it will possibly be weakened
mangogrooveworkshop - 30/4/12 at 04:14 AM
Not the best thing to think of straightening considering its function.
Replacement
Take it to D&A motor factors and they will be able to I'd which one it is.
[Edited on 30-4-12 by mangogrooveworkshop]
snapper - 30/4/12 at 11:09 AM
Cortina had a pressed wishbone of sorts so should be Escort
Don't straighten a cast item, the damage has been done, straighten it and you just pull the stress fractures apart.
Hellfire - 30/4/12 at 11:38 AM
Personally, I'd straighten it. It can't be too badly bent if it was caused by a pebble and I doubt that bending it back would weaken it to the point of it being unsafe. Just my personal opinion though, I am no metallurgist and have no idea how badly bent it is.......
Phil
Peteff - 30/4/12 at 12:22 PM
We're getting a bit confused here, is it a track rod or a track control arm. If it's a track rod I've straightened them in the vice with no ill effects and if it's a track control arm how big was the bl**dy pebble ?
scootz - 30/4/12 at 12:28 PM
I think I have an old Cortina rack somewhere in my garage. You're welcome to it... if I can find it!!!
I'll get back to you later today.
scootz - 30/4/12 at 02:48 PM
Yup - still there and still has the rod arms attached!
Hellfire - 30/4/12 at 04:32 PM
If the Escort/Cortina rack is anything like the Sierra rack below, surely it can only be the tie rods that have bent?
Phil
Sierra Rack
Sierra Rack
Murphy - 30/4/12 at 06:55 PM
U2U sent cheers
Phil
Sierra Rack
Sierra Rack
Murphy - 30/4/12 at 06:59 PM
Thanks for the replies everyone.
Scootz I sent you a u2U
It's the tie rod ends and yes it was slightly more than a pebble. I was just doing the play it down thing.
Cheers again
scootz - 30/4/12 at 07:11 PM
Replied.
