I've installed new callipers, changed pads and discs before but on modern cars.
I took the front wheels off my Tiger Avon today and found a setup I've never seen before. I'm guessing you have to take the hub nut off to
take the disc off but can anyone confirm ??
See pic below
I think the hub is from a Cortina ???
Yup
Just changed the discs on mine recently
Remove the hub from the upright and you'll see the 4 nuts holding the disc to the hub.
Brilliant, cheers mate
Not quite as simple as that you need to adjust the wheel bearing end float properly when you build it back up or you will knacker the wheel
bearing or worse have wheel seize solid on the road.
Do a search a forum on adjusting Cortina wheel bearings,
Will do
Glad my disc looks nearly new then
Originally posted by britishtrident
Not quite as simple as that you need to adjust the wheel bearing end float properly when you build it back up or you will knacker the wheel bearing or worse have wheel seize solid on the road.
The discs and pads look fine. Why are you changing?
Just wanted to know for the future
