I am replacing the gear knob on my F27 to a Richbrook one , but need to replace the plastic tube insert as the old one had split, does any one have
a spare one lying around ? think its 8mm
or know where I can get one from - tried e-bay
thankyou
I've used body filler paste(suppose you could also use JB Weld or similar) on a couple of gear-knobs.
Wrap the gear-lever in cling-film making sure it comes quite a long way below the thread.
Whack some mixed filler into the knob, trying to make sure it goes in all the way, then place it over the gear-lever, lining it up how you want
it.
Simples....
HTH.
Cheers, Pewe10
8mm nylon bar and drill it...
Heat gear lever with small torch. Smear hot melt Glue on Lever, fit knob over the top and position. Leave to cool.
I did this with a Pool 8 ball, it never moved in 6 years.
Also easy to remove by re-heating the lever again.
Do NOT put HMG in the hole in the ball / knob, it cools too quickly when it hits the cold lever.
This works well and is easy to remove.
Thanks for the replies to date,
but all I'm after is the plastic insert, as I still want to be able to remove it quickly if needed.
can anyone help out?
ta
