Can anyone recommend a fuel filter and where to purchase it for my '03 R1 injected engine.
Do I fit a filter before the fuel pump or just fit one after fuel pump.
If your not using the oringinal R1 pump,which has a filter built in,you need a high flow rate filter specifically for fuel injection,before the pump
is best,check out EBAY item number 150208922005.this is ideal for your application.
Try MNR themselves or Europa spares under fueling they have a small see through bike filter for £1.50ish and sounds fine for all bike engines
I have a small low pressure filter before the pump and a high pressure filter after it.
The small filter adapts the output of the tank to the input of the fuel pump and the high pressure one is from a Ford Focus
