Hi all I'm currently looking at a couple of Pinto powered Westies that fit my budget.
Both have standard coil/distributor ignition set up and carbs (twin 45's or bike carbs).
I'd probably look at upgrading to an ignition only ECU like Nodiz to get the most out of the engine.
How easy is this to do and is it worth the money?
Future long-term plan would possibly be to replace with a Duratec or similar.
What sensors would I need other than crank sensor and trigger wheel?
Would the standard Zetec loom with TPS and crank sensor work on the pinto?
How would I wire a TPS to carbs?
Also how's the best way to sort out ditching the distributor whilst retaining the oil pump drive?
You could run MAP instead of TPS or use bike carbs that already have TPS
you can leave the distributor in place and just cover off the distributor cap, there are some cut down flush adaptors with a short distributor drive
and gear that does the job.
https://www.ebay.co.uk/itm/Cosworth-Distributor-Aluminium-Blanking-Cap-Sierra-Escort-Rs-Wasted-Spark-/174604236953?mkcid=16&mkevt=1&_trksid=p2
349624.m46890.l6249&mkrid=710-127635-2958-0
https://www.ebay.co.uk/itm/COSWORTH-WRC-DISTRIBUTOR-BLANKING-DRIVE-BUNG-WRC-GROUP-A-SIERRA-ESCORT-MOUNTUNE-/182317468317?mkcid=16&mkevt=1&_trk
sid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
[Edited on 3/11/21 by snapper]
Mapped ignition won't really add any power. You could get better mid range torque and increased economy at cruise.
But if thinking of alater engine change no harm, as long as you plan to keep carbs and not go EFI.
If thinking of efi, why not get a full ecu and be ready to add injection later?
A TPS is not difficult, all it does is fit to the carb spindle using a little bracket. They may be available premade, or make your own.
Loom, I expect nodiz would have a Ford TPS connector and coilpack connector, plus the nodiz plug. You would need to source a coilpack and set of OE
(or at least very good quality) leads.
Other alternatives are megajolt, which is probably more reliable than nodiz. And of course any full ecu.
Originally posted by cliftyhanger
...But if thinking of alater engine change no harm, as long as you plan to keep carbs and not go EFI.
just a though - If you'd like a cheap easy option to add some reliability you could just do a strait swap for a electronic dizzy on the pinto
I think H&H ignition aren't all that far from you (Brierley Hill) and I found them very easy to deal with
https://www.facebook.com/HHignitionsolutions/
Thanks all.
Not sure about engine swaps etc - as this would be my first 7, so would be to see how it goes & hoe much I use it.
I'm thinking mappable ignition more from the point of drivability rather than performance - especially as some (most) of the cars I've
looked at have non-standard cams fitted.
I'll take a look at the Megajolt system too - thanks.
I知 running Megajolt with MAP sensor, on a dyno apparently TPS is easier to hold steady on a particular load bin.
I have only just recently worked out what the light load ignition timings should be, basically add 1 degree per load site from the WOT numbers as a
start point.
I found a calculator online that got me started
^^ What does your map look like now / do you have screen shot of it?
I've collected a handful base maps for pinto's in different tunes if anyone needs a starting point
The map is for a high compression 2.1 with ported big valve head running. RL31 cam so not relevant to any other Pinto.
Due to the engine idling at 1000+ rpm the timing rises later and therefore you get a steeper curve.
What I have also learned is that unleaded fuel burns quicker so the old mantra of 36 to 38 degrees at 3600 to 3800 is essentially wrong and 30 to 32
more reasonable.
Based on a standard distributor ignition curve you would run idle ignition to 3600rpm along the high load low vacuum row and add 1 degree per load
row.
This gives me a base for the dyno tune.
In reality your ignition would track from low load idle diagonally to high load across the map and a dyno can hold engine revs allowing you to map
each rpm column.
^^ I'm fully expecting to have to go through all that too (hopefully soon, just got a few issues to resolve with the sump first )
Mine is closer to your spec than the average pinto so its good to get some ideas for a starting point
for now I've only got std. valves in mine, but on bronze guides with a piper 285 cam (270ー/290ー at 11.81mm lift so a bit less than your RL31, but
more than the FR32 most folk seem to fit)
thats fitted to a effectively cossie bottom end with 93mm flat top pistons and should be about a 10.5:1 CR (DCR~8.5:1 about as high as I dare for
now)
the maps I've managed to find aren't really close enough to my spec so I'm expecting to have to change them a fair bit:
(^^ these two are supposedly a stock engine and a big valve monster)
PS - if anyone wants copies of these maps (and a few others) just ask
[Edited on 4/11/2021 by mcerd1]
All the megajolt/nodiz/cannems are pretty much the same , megajolt is getting a bit long in the tooth and needs the ford coil pack driver so would
avoid as others have it pretty much built in or can drive stand along coil packs like VW polo/vauxhall etc which is neater and easier to source and 1
less thing to go wrong.
If you want to get the best out of the pinto dizzy for a race cam they can be mapped and its not particularly difficult to do yourself ( if you know
how).
Standard pinto needs advance of about 12 degrees tickover @ 850rpm and max 40 degrees at 4000rpm +
A race cam + head skim needs 18 degrees advance at tickover @ 1100rpm and max 34 degrees at 3000 rpm+
The dizzy has 2 springs , 1 light and 1 heavy . Change the heavy one for a light one so there are 2 light springs .
bend the spring holders so the the springs are just held by the posts there on.
bend the advance weight limit tabs in a bit to limit there throw
Try it on the engine and test with a timing light that has an advance adjust + shows RPM.
Have made a few dizzys in the past and it turns a horrible lumpy / boggy engine into something a lot more drive-able, unfortunately ive binned/sold
all my pinto stuff as got fed up working on them.
for now I've only got std. valves in mine, but on bronze guides with a piper 285 cam (270ー/290ー at 11.81mm lift so a bit less than your RL31, but more than the FR32 most folk seem to fit)
thats fitted to a effectively cossie bottom end with 93mm flat top pistons and should be about a 10.5:1 CR (DCR~8.5:1 about as high as I dare for now)
A simple alternative may be to use a 123+ tune - this replaces the distributor and is fully programmable by bluetooth. It is really simple to
install, literally just swaps for the dizzy! I have one in my supercharged MGB
https://123ignition.com
Originally posted by JC
A simple alternative may be to use a 123+ tune - this replaces the distributor and is fully programmable by bluetooth. It is really simple to install, literally just swaps for the dizzy! I have one in my supercharged MGB
Looked at those (also mentioned on a WSCC forum thread) but they don't do a Pinto version.
Originally posted by snapper
Second map looks close to mine but I知 running load bins 10 to 100 on MAP any thing above about 103 is boost
What I have also learned is that unleaded fuel burns quicker so the old mantra of 36 to 38 degrees at 3600 to 3800 is essentially wrong and 30 to 32 more reasonable.
Based on a standard distributor ignition curve you would run idle ignition to 3600rpm along the high load low vacuum row and add 1 degree per load row.
In reality your ignition would track from low load idle diagonally to high load across the map and a dyno can hold engine revs allowing you to map each rpm column.
If I知 reading the first post right you have not got a car yet if so how do you know if the ignition needs changing
I had a H&H ignition modified dizzy and I had no problems at all
If you search my posts you will see what was modified to my pinto
Jacko
