Compression test on XE Red Top
Pants On Fire - 17/3/08 at 04:12 PM
Can anyone tell me what sort of psi I should be getting per pot on my XE?
I've google'd and checked the Haynes manual no joy.
02GF74 - 17/3/08 at 04:54 PM
approx CR * 14 psi allowing for some inneficiicney of cylinder filling at low rpm.
will see if I can find someting out but seem to rememebr most values tend to be in range 150-180 psi.
Pants On Fire - 17/3/08 at 05:21 PM
Thanks. I had a figure of 165 psi in my head as an approximation.
Did a track day Saturday and burnt rather a lot of oily stuff, hope it's guides or a valve rather than glazing or rings
alistairolsen - 17/3/08 at 05:30 PM
make sure theyre all even and around 12 bar *ish* its not an exact science tbh,and every tester is different, as are starter motors etc. Most important is that they are even
