Author: Subject: R1 Overheating - Help please
Kriss
posted on 21/11/08 at 03:47 PM Reply With Quote
My R1 (2003 engine Indy) has been a dream to own and drive scince passing its SVA in July.
Opened up the bonnet for a general check today to see I have lost lots of water from the header tank. checked the level and it was very low.
So filled it up, went for a drive and got home, wanted to see if it over heated and if the fan came on, picked up temp quickly and then the coolant tank pissed out water.
Could this be thermostat or something worse?
will get pics up etc.
I have next week off work so a good time to fix it.
any advise would be tops too
adithorp
posted on 21/11/08 at 03:54 PM Reply With Quote
What was the temp when it came out? R1 fan doesn't cut in till 105'c. Could just be a faulty presure cap. Yoy did leave space in the bottle didn't you?
adrian
http://jpsc.org.uk/forum/
Kriss
posted on 21/11/08 at 04:01 PM Reply With Quote
its was about 95 when the water came out.
Is the pressure cap the cap that is on the header tank.
i did notice the top hose start to steam moments before it blew its load lol
what a good routine to do to check whats at fault here?
l0rd
posted on 21/11/08 at 04:16 PM Reply With Quote
I would imagine the pressure cap.
TimC
posted on 21/11/08 at 04:20 PM Reply With Quote
Yeah - nice and cool at 95 - change your cap.
adithorp
posted on 21/11/08 at 04:21 PM Reply With Quote
Sounds like the caps not holding presure. Get it checked or just stick a new one on and see what happens.
adrian
Kriss
posted on 22/11/08 at 11:29 AM Reply With Quote
guys - do you mean the actual screw on cap that you undo to fill up the coolant in the header tank?
secondly, the top hose of the coolant tank started to steam just before the tank leaked, so thats must mean its under mega pressure no?
Kriss
posted on 22/11/08 at 12:21 PM Reply With Quote
topped up the water againa nd started it up. the cap for the coolant tank had steam coming out of it after about 80 degrees, pretty sure the cap is failing.
any other suggestions?
adithorp
posted on 22/11/08 at 10:40 PM Reply With Quote
Either you need a new cap or you've got serious problems (ie. headgasket). Cheap enough to change the cap and find out.
You could of course take the head off and check that first to save wasting money on a cap you might not need!
adrian
Kriss
posted on 22/11/08 at 11:23 PM Reply With Quote
new cap for £3.10 and it seems to have done the job
97-98 degrees, fan came on, no leaks, temp reduced dpwn to high 80's, job done - fingers crossed
cheers for your help dudes
