Author: Subject: Erratic Needle on Clocks
spdpug98
posted on 23/2/09 at 03:44 PM Reply With Quote
We got the loom sorted on my 2003 R1 install yesterday (eventually!) and had the engine turning over
But I have a problem with the clocks, the needle goes very erratic when you switch the ignition on and the just stops anywhere (differant place each time)
It did once do the normal swish around and settle at 0 but since then it just goes mad
Anyone have any ideas
My Blog: http://spdpug98.wordpress.com/
vinny1275
posted on 23/2/09 at 03:51 PM Reply With Quote
which clock - rev counter / speed, or both?
spdpug98
posted on 23/2/09 at 03:58 PM Reply With Quote
Should of explained myself
It is the standard R1 clocks and it is the rev counter needle
bassett
posted on 23/2/09 at 04:15 PM Reply With Quote
I know the exup causes funny needle readings although i thought it was only when running. have you got your exup valve fitted or replaced it with a mini circuit faking the exup being there.
[Edited on 23/2/09 by bassett]
spdpug98
posted on 23/2/09 at 04:36 PM Reply With Quote
The exup is disconnected but I have not wired in the circuit board yet. I will have another play tonight with and without the exup valve
amalyos
posted on 23/2/09 at 09:13 PM Reply With Quote
If the Exup is not connected, then it will make the needle go mad.
It should stop when you connect it.
http://stevembuild.blogspot.com
