Author: Subject: blade temp sensor
bigfoot4616
posted on 9/3/09 at 08:49 PM Reply With Quote
blade temp sensor
need to fit a ETB temp sensor to my 919.
i was hoping it would screw straight in to the existing location but i don't think the thread is correct.
where is the best place to fit it to get accurate readings?
cheers
mark chandler
posted on 9/3/09 at 09:21 PM Reply With Quote
I pulled out the sensor in my blade engine, plucked off the hose outlet and stuffed with rags then redrilled and tapped to take a standard car sensor.
There is lots of room in there for this. It is a really good place for it, when datalogging my jaw you can see immediate changes in values when applying throttle which is what you need.
If if all goes horribly wrong all you have to do is wind in a bank and retap to the original size.
Regards Mark
bigfoot4616
posted on 9/3/09 at 09:53 PM Reply With Quote
problem with drilling end tapping the existing location is the hole size is correct, just the wrong thread. the new sensor will screw in a turn or so then gets tight.
not sure what the standard sensor is , the ETB one is 1/8" NPTF
daviep
posted on 9/3/09 at 10:08 PM Reply With Quote
The original was probably 1/8" bsp then. NPT is slightly larger (about 15 thou I think) and has 27 tpi as opposed to BSP which is 28 tpi.
You'll get away with running an NPT tap in to it if you have one.
Davie
bigfoot4616
posted on 10/3/09 at 06:19 PM Reply With Quote
i should be able to get hold of one.
whats the difference between NPT and NPTF?
cheers
