macspeedy
| posted on 20/3/09 at 08:54 PM |
where to put a heater in the plumbing ??
I am getting the bits together for the cooling system on the zx12 install and was wondering where people recon the best place to put the heater /
demister system. ie between water pump out and oil cooler or between pump feed and pump... ??
Mac
blakep82
| posted on 20/3/09 at 09:18 PM |
i think theres normally 2 take off points on the cylinder head isn't there?
________________________
smart51
| posted on 20/3/09 at 09:50 PM |
My heater is taken off between the head and the thermostat. The return tees into the pipe from the rad to the water pump, which feeds cool water into
the engine.
Paul TigerB6
| posted on 21/3/09 at 09:19 AM |
This is the BEC section......... surely you cant be allowed to say such blasphemous things as "adding a heater / demister" to your
lightweight car in this section!!
macspeedy
| posted on 21/3/09 at 11:46 AM |
I have 2 outs from the engine block, one goes to the oil cooler the other goes to the water pump. will i get enough flow, or could i possibley
interrupt a necessary flow ?
Mac
