Author: Subject: Fuel pump
rgrs
posted on 4/7/09 at 10:31 PM Reply With Quote
Fuel pump
Strange issues since iv'e been on the road
893cc blade fine up to 65mph and then at motorway speeds (70 ish) its fine for about 1 minute then loss of power and backfiring.
its running a R1 carb fuel pump
As soon as you stop and restart its fine again ??
Your thoughts appreciated ?
Roger
cloudy
posted on 4/7/09 at 10:37 PM Reply With Quote
Almost certainly fuel starvation, have you checked all the lines/filters are clear?
James
www.warnercars.com
Major Stare
posted on 4/7/09 at 10:48 PM Reply With Quote
Fuel filter fitted? If so, what type?
Loose conection on fuel pump electical curcuit?
Jon "FISH"
big_wasa
posted on 5/7/09 at 07:16 AM Reply With Quote
Fuel breather ?
mad-butcher
posted on 5/7/09 at 07:40 AM Reply With Quote
try it without fuel tank filler cap on, if that cures it then it's a fuel tank venting issue
tony
britishtrident
posted on 5/7/09 at 10:06 AM Reply With Quote
Most likely cause is a restriction between the suction side of the pump and the tank.
Remove filler cap, remove fuel pipe at pump inlet a blow back to the tank with a foot pump or low pressure air line.
Jon Ison
posted on 5/7/09 at 10:22 AM Reply With Quote
Originally posted by big_wasa
Fuel breather ?
Definite possibility this one.
rgrs
posted on 5/7/09 at 07:24 PM Reply With Quote
Thanks all, working my way through the list now.
Roger
