gixermark
| posted on 18/8/09 at 01:00 PM |
919 vs. 929 Blades - specs ?
Hi Guys,
trying t get actual power/torque figures for these two engines...
i thought the power was within a few HP - but looking at MCN tech specs they give
128hp/58 ft/lb for the 919cc
152hp/76 ft lb for the 929cc
anyone have any other figures ? or better still rolling road comparisons for std engines ??
the_fbi
| posted on 18/8/09 at 01:05 PM |
http://www.honda-fireblades.co.uk/specifications.html
gixermark
| posted on 18/8/09 at 01:13 PM |
cheers for link....
strange that figures vary so much... the 7hp sounds closer to what i'd expect... but would like to know whether the other figure of 152bhp comes
from in MCN.....
Mmmmnn
franky
| posted on 18/8/09 at 02:41 PM |
on a motorbike.... with full systems my old blade made 118bhp at the wheel and my following 929 made 130bhp at the wheel both set up on a realistic
rolling road. The 954 then made 147bhp but I think the gearbox's have a dodgy 2nd/3rd gear. These were all on the same dyno but over a few
years.
Best bike engine bar my current bike was a honda sp1 which made 135bhp but at lower revs and with more torque. Should really be better in a BEC....
you also get HRC on the crank cases too!
I'm looking out for a morini corsaro engine as thats what my bike is at the minute... that makes 145bhp at the wheel at 9000rpm. if you put the
dyno curve over a 'busa' it makes more power and torque till it runs out of revs
Plus it sounds like rolling thunder
gixermark
| posted on 18/8/09 at 02:51 PM |
cheers - thats a fair bit more for the 929... interesting.
PAUL FISHER
| posted on 18/8/09 at 03:16 PM |
I ran a 929 rry in my 1st Indy,they are a great engine,the main difference with the 929 over the 919 is that it was the first of the fuel injection
engines,although did not produce much extra power over the 919's,mine made 124bhp at the wheels with a power commander and a race can.
The main thing is if your thinking of fitting one of these engines is to ensure you have a matched ECU and key,as it has the HISS system fitted,and
will not start without it,and cannot be easily bypassed
