Lightning
| posted on 10/4/04 at 05:27 PM |
Help with Blade starting
I have had the blade engine started before. Today it revved once, then tried to start again ,having none of it.
Checked fuel to carbs...OK
Took out pluge...soaking. Turned over withouut plugs to blow out fuel... Checked spark on plugs ..OK.
Put plugs back in and still no joy. Puzzled.
Not being used to bike engines, what is the best way to start them.
Tempted to use choke but dont want to flood it.
Whats the best way to blow things through. Same as a car ,full throttle?
If it ran before therefore the spark timing surely is ok.
Help.
| posted on 10/4/04 at 05:39 PM |
We had a battle with a Yamaha Diversion yesterday. It was trying to fire but wouldn't start. The spark was very weak so we tried cleaning the
plugs, then there was no spark at all. They had only done 600 miles but we swapped them for new NGK ones and it ran straight away. Binned the old ones
and it starts first touch now.
Lightning
| posted on 10/4/04 at 05:58 PM |
I'll have to get new plugs...BUT
I just weny for a burn down the road!!!!!!!!!!!!!!!
Clutch works, brakes work...thank god!
Fan cut in ..but to my suprise blew the air foward not back.
Micra rad and fan
Oooo errr
What have others done
Never mind still had a blast!!!!!
Berwyn
| posted on 10/4/04 at 06:38 PM |
RE: blew the air foward not back.
Eh ! . my micra rad sucks air in. If you are sure this is the problem, make sure you are switching on the earth, not the live, as it is designed to
switch on earth. Of course, if it is wired backwards, the fan will run backwards
24 hours in a day, 24 beers in a case. Coincidence? I think not
Lightning
| posted on 10/4/04 at 07:32 PM |
Just looked at wiring and it is switched n the live . Will swop the wires around.
I have to say the clutch was not as bad as I thought it would be , quite progressive.
Also pleased that the car doesnt bottom on the brow of the hill up my drive.
I forgot to mension I havnt got a tank yet, as its still being made. Went down the road with green plastic tank on the passengers seat and the hose
draped in.
I now only have to bolt the seats in ,bolt in the harnesses and fit the wind deflector.
Hellfire
| posted on 10/4/04 at 08:46 PM |
NGK Spark Plugs
There is a very strong thread going around the Yahoo Forum about flooding your plugs... specifically irridium one's. The subject matter is that
once you flood the irridium one's they will not re-start whether they are cleaned or not! You can tell Irridium one's as they have waisted
down centre with an annular groove on the top (very small).
I must add that we flooded our plugs and found it difficult to restart, but when new plugs were put in, it started first time. BUT, the old
one's had a MASSIVE gap... we haven't tried the old one's since so we've reached no conclusion as to above subject.
To summarise - I'm curious as to whether anyone else has had problems with precious metal (irridium plugs) after flooding. If you have - please
post as it will be in your collective interests.
| posted on 10/4/04 at 11:01 PM |
Iridium plugs.
We didn't have a problem with them, they were £7+ each so we didn't buy them
Lightning
| posted on 16/4/04 at 09:58 AM |
How much for NGK plugs. I just went to local dealer and was told £8.oo each !!!!
Is there somewhere anyone can recommend to get some
| posted on 16/4/04 at 10:08 AM |
I got the replacements for the Divvy from spares shop the wife drives for on Saturdays. I think they were CR8es and were £12.72 for 4 inc. vat. Bike
shop wanted £24+ for same plugs.
[Edited on 16/4/04 by Peteff]
Lightning
| posted on 16/4/04 at 10:27 AM |
Pete
Mine are CR9EH-9 Can I use the ones you said . What is the difference?
| posted on 16/4/04 at 12:38 PM |
CR9E are £2.71 + vat. I don't know what the H-9 bit signifies. That makes them the same price as the ones we bought for the divvy. I think the
difference is the heat range so probably best left alone.
Found the H-9 bit, it's just the tip and gap specs so they are same bog standard plugs not platinum or iridium.
alister667
| posted on 16/4/04 at 08:52 PM |
Mine are NGK CR9EH-9 and have been in and out of my engine like a fiddlers elbow! There doesn't seem to be a problem once I give them a clean
and reset the gap (I think it was in around 30 thou or maybe 32 - it's in the haynes somewhere).
They cost about 8 quid apiece and came from a honda dealer.
http://members.lycos.co.uk/alister667/
| posted on 17/4/04 at 09:20 AM |
I asked this morning.
The CR9EH-9 are different to CR9E. The electrode and insulator are different. They are dearer than the CR9E but not £8 each with staff discount. . If
the postage isn't too much I could send some. Do you want to look into it?
[Edited on 17/4/04 by Peteff]
Lightning
| posted on 17/4/04 at 07:48 PM |
Thabks very much for the offer Pete, but I bit the bullet today and bought some. The engine fires first time now and runs sweet.
Just hope they last a while.
Picked up the tank today BTW. From local chap. Ali with baffle plate. £70.00 Made to measure. Nice job.
mdc124
posted on 22/1/05 at 08:54 PM |
Follow up
Just to add another post to this in case anyone needs to find this problem.
My engine just stopped firing - ran on thursday night - friday nothing. (it's been off road for a year and the mot was due today - but thats a
different story)
Cleaned plugs - ran for 10 secs - died
Cleaneda gain - 5 secs (after alot of swearing) - died
£35 of CR9EH-9 later - fired up first tickle.
Seems these plugs just dont like fouling up.
Key words: Plug fouling, NGK CR9EH, Fireblade, spark plug, problem
i know this is one huge knowledge base - i just wish it was easier to find things - anyone want a wiki?
Http://www.farend.co.uk/
The first MK Turnkey Indy
ReMan
| posted on 22/1/05 at 11:02 PM |
Had same prob myself whilst engine was still in bike.
Advice I got was its a common problem, often caused by trying to start with a weak battery, then a flooded engine.
The cure, apart from a charged battery, is cleaning, then cooking the plugs over a gas ring and putting them back in warm, just as those who used to
ride 2 strokes will probably have done in the winter.
Running the flooded plugs out will see them arcing down the centre electrode.
Even so I would like a shiny new set of CR9EH-9, whats the best place/ price, including post anyone?
www.plusnine.co.uk
shortie
| posted on 23/1/05 at 09:24 PM |
Same for me aswell, tried old plugs and fiddling with them a bit, new plugs in and vroooommm, sweet.
