Jon Ison
| posted on 14/3/10 at 08:45 PM |
Flatshifter
Retained the flatshifter used on the Blade and now ready to wire it into the Busa loom, trouble is I cant find the book anywhere.
Can someone who as instruction book tell me which colour wires to break into on the Busa ?
Ta.
sucksqueezebangblow
| posted on 15/3/10 at 02:13 PM |
Hi Jon,
I've got the instruction manual for the Flatshifter Expert at home. I think the wiring will be the same except for the "cut" wires
(it cuts injectors instead of spark). I'll dig it out tonight and try to remember to scan it for you tomorrow.
Jon Ison
| posted on 15/3/10 at 10:12 PM |
if you would, would be very appreciated,
sucksqueezebangblow
| posted on 16/3/10 at 01:11 PM |
Nipped home and got it this lunch time. I've got both; the Pro manual and the Expert manual. I assume you need the Pro.
Black = Battery negative or good chassis earth.
Brown = Switched +12 volts(from ignition switch or convenient switched live.
Blue = Ignition coil supply wire (ECU side)
Orange = Ignition coil supply wire (coil side)
Red and Red/Black = Red and Red/Black from Downshifter Control Box.
[img][/img]
Jon Ison
| posted on 16/3/10 at 04:22 PM |
Thank you, locostbuilders at its best yet again.
Very much appreciated.
