phelpsa
| posted on 14/5/04 at 03:35 PM |
Fuel pump
What pressure (psi) and flow fuel pump will I need for my GSXR1100 engine. I espect it is the same as most bike engines.
Adam
ChrisGamlin
| posted on 14/5/04 at 03:39 PM |
If its a carbed engine (which assume it is) then you usually need about 1.5psi of pressure. Im not sure on flow rate but any fuel pump off a bike
carbed bike should do the trick.
phelpsa
| posted on 14/5/04 at 03:45 PM |
Thanks chris, now i'll know what to look for at the Beaulieu autojumble tomorrow.
Adam
ChrisGamlin
| posted on 14/5/04 at 04:05 PM |
That should have read "big carbed bike" , ie one from a bike engine of a similar capacity to yours.
Having said that I think most of the bike pumps are the same anyway, usually made by Mitsubishi, blades use the same ones as CBR600s etc.
Don't go for a pump that isnt pressure sensing though (like the Facet ones) because you'll need a regulator in there as well which have
been known to cause flowrate issues at such low pressures.
Chris
[Edited on 14/5/04 by ChrisGamlin]
phelpsa
| posted on 14/5/04 at 04:08 PM |
I should probably go for the one that they use in the 'busa engined cars. They must be right.
Adam
ChrisGamlin
| posted on 14/5/04 at 04:57 PM |
No you shouldnt, cos they are fuel injected so will give you about 45psi !!!
phelpsa
| posted on 14/5/04 at 05:47 PM |
Weren't the early ones carbed?
Adam
| posted on 14/5/04 at 07:21 PM |
i got a mitsubishi one, apparently from a blade engine. is this ok? anyone?!
ChrisGamlin
| posted on 17/5/04 at 09:58 AM |
Adam
Not AFAIK, Im pretty sure they were all injected.
Joel - yep that one should do fine, same as what I use on my blade.
