david cromie
| posted on 17/5/04 at 10:23 PM |
HT leads
I have moved the coils on the fireblade engine and have had to use longer leads. the leads are the wire centre type. the sva states that the leads
must not cause interference. will the wire pass the sva. I am using the fireblade plug caps. If carbon leads have to be used how do you fit them the
the Honda pkug caps? david
ChrisGamlin
| posted on 19/5/04 at 01:47 PM |
You need HT cable that is marked to confirm that it supresses interference, you should be able to get it from a motor factor etc.
Chris
alister667
| posted on 19/5/04 at 06:37 PM |
I had trouble getting this lead in NI, so I wound up buying some HT coil leads and chopped them, then made my own leads up using dodgy roger's
info. It's fairly straight forward.
My leads say Hotwires Silicon 15kohms. I can't say for definite if the SVA guy looked (he probably did) but I'd say as long as he saw the
15kOhm and the Silicon bit's he'd have been satisfied.
http://members.lycos.co.uk/alister667/
