Author: Subject: should i get torque tube with PROP????
jossey
posted on 16/6/10 at 11:24 AM Reply With Quote
Just spoke with dunning.
they gave me ideas.
they said it will bolt straight onto my motorbike gearbox 11/40 series?
that right?
i thought i need a sprocket adaptor
[Edited on 16/6/10 by jossey]
posted on 16/6/10 at 11:53 AM Reply With Quote
Put the diff in the car..
Dunning & Fairbank for the prop.
daviep
posted on 16/6/10 at 11:59 AM Reply With Quote
That oil seal doesn't look quite right, what's going on at the 7 o'clock position?
Davie
posted on 16/6/10 at 12:15 PM Reply With Quote
Its a cloth or summit innit???
jossey
posted on 16/6/10 at 12:38 PM Reply With Quote
yes its a cloth and the rubber is just moved due to stuffing the cloth in. its fine though.
who shall i get my prop from?
Dangle_kt
posted on 16/6/10 at 01:29 PM Reply With Quote
x2 thin paint, but the rest is great quality.
Bluemoon
posted on 16/6/10 at 02:25 PM Reply With Quote
Not sure what you mean by torque tube, I assume you mean the "prop" torque tube tends to refer to a tube around the prop it self, a method used by ford and some others, the early 7's used this setup.
In this case the stationary torque tube holds gearbox and diff (or gearbox) together, not needing chassis to transfer the torque, neat idea...
i.e:
Dan
[Edited on 16/6/10 by Bluemoon]
franky
posted on 16/6/10 at 02:30 PM Reply With Quote
yep get one, the torque resiliant tube acts like a rubber cush drive in the bikes wheel helping to protect the gearbox.
posted on 16/6/10 at 03:28 PM Reply With Quote
I've got one on mine. Mostly because it's got the gearbox outlet attached to the end of it so I just had it chopped it half then wacked up the chuff of a cut-down prop (after a little turning on a lathe) and welding in place.
jase380
posted on 16/6/10 at 06:24 PM Reply With Quote
you still need to get a sprocket / prop adaptor, it wont bolt onto a sprocket !!
jossey
posted on 17/6/10 at 02:41 PM Reply With Quote
thanks again guys!
cheers
dave
