Author: Subject: gear ratios for 2008 engines wanted
MK9R
posted on 23/6/10 at 11:52 AM Reply With Quote
Looking at what engine to put into the Fury for 2011 season, looking at 2008 CBR or R1, but struggling to find info on gear ratios and max rpm to stick in calculator. Anyone help??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
posted on 23/6/10 at 12:03 PM Reply With Quote
ok, got ratios now, just need rpm limits
Cheers Austen
RGB car number 9
www.trackace.co.uk
matt_gsxr
posted on 23/6/10 at 12:04 PM Reply With Quote
www.gearingcommander.com
progers
posted on 24/6/10 at 07:55 AM Reply With Quote
Hi Austen,
Use 13k max for the CBR and 13,750 for the R1. The R1 is better suited for your 3.54 live axle - it should be good for around 135 which is fine for any track we race on. The CBR is the stronger motor (especially in the midrange) so would be the motor of choice if you were independent rear. However, your car will still go like stink with the newer R1.
Paul
MK9R
posted on 24/6/10 at 08:00 AM Reply With Quote
Hi Austen,
Paul
Cheers paul, I'd come to the conclusion the r1 was slightly better suited to the live axle, its just the height of it which I a pain in the fury. The thought of an extra 50bhp in my little white bumper car is pretty terrifying!
Cheers Austen
RGB car number 9
www.trackace.co.uk
progers
posted on 24/6/10 at 08:23 AM Reply With Quote
In reality its more like 30hp at the wheels, but still nice to have nonetheless! If there are enough people going R1 maybe there is scope for Mr Bates to do a custom airbox to reduce the airbox height?
Dump the variable height trumpets and relocate the secondary injectors and you could reduce the bonnet bulge quite significantly I'd guess.
- Paul
BobM
posted on 24/6/10 at 12:21 PM Reply With Quote
Originally posted by MK9RThe thought of an extra 50bhp in my little white bumper car is pretty terrifying!
Yes, I think there are a few of us terrified at the prospect of you having an extra 50bhp
TimC
posted on 25/6/10 at 09:54 AM Reply With Quote
That should be exciting enough to warrant your own AMTV clips show!
