Author: Subject: R1 questions.
Pezza
posted on 21/7/10 at 09:57 AM Reply With Quote
R1 questions.
Trying to get some more done on the Indy of late and want to pick your collective brains about a few things please
Is this an idle adjuster? or is my guess wrong?
Do I need whatever this is?
And finaly for now. What are these pipes for? (circled in red) are they something to do with coolant for the carbs, and do I need the in the indy?
Ben
[Edited on 21-7-10 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
Stuart_B
posted on 21/7/10 at 10:00 AM Reply With Quote
the first one is a idle adjuster from the looks of it.
the other two, i am not certain on
stuart
smart51
posted on 21/7/10 at 10:23 AM Reply With Quote
The idle adjuster is a simple stop to prevent the throttle butterflies closing completely. It is handy for setting the revs to 2500 RPM for emissions testing so you can leave the throttle pedal alone.
I can't see the pictures (work internet blocks some hosting sites) but there is a brass pipe through the carbs. You pass warm coolant through it and it stops carb icing in cold weather. I only found it to be a problem in freezing fog and a trickle of warm coolant to my header tank sorted it.
Miks15
posted on 21/7/10 at 11:52 AM Reply With Quote
im pretty sure the one you circled on the bottom left is the fuel inlet
jack_t
posted on 21/7/10 at 12:06 PM Reply With Quote
in the top pic il looks like u have connected the fuel line from the tank to a t piece which go's to 2 pipes to the top of the carbs
these are breathers
idler
the second picture is like filter/regulator for the emmisions system which u dont need to run so it can go
the third pic
bottom left if fuel inlet and top right is for coolent i dont run it on the indy as i dont have any problems
[Edited on 21/7/10 by jack_t]
Pezza
posted on 27/7/10 at 06:08 PM Reply With Quote
Thanks for replys might have saved me putting fuel in the wrong place come first start up lol
