Author: Subject: zx12r - another wiring question
locostbuyer83
posted on 20/8/10 at 08:53 PM Reply With Quote
hey guys,
ive searched and couldnt find anything about this..sorry if its a repost...
wiring my zx12r into my indy...
engine turns, fuel pump runs as it should but no spark and injectors are not pumping out fuel.
weird thing is i disconnected the chucky connector to the starter and when i flick the key the speedo flickers up and down between 0 and 10mph
i know its a wiring fault but just need a clue to how to narrow it down.
many thanks
eznfrank
posted on 20/8/10 at 09:15 PM Reply With Quote
Have you done all the safety switch bypasses, clutch, side stand, tilt etc?
locostbuyer83
posted on 20/8/10 at 09:37 PM Reply With Quote
The side stand is plugged in but in the correct position, it does nothing otherwise. The clutch switch is wired to ground, didn't work til I did that and the tilt sensor is plugged in but flat, still in battery tray in car
Flamez
posted on 21/8/10 at 05:13 AM Reply With Quote
Tilt sensor should be mounted vertical with the arrow ointing upwards.
my build mac1motorsports
locostbuyer83
posted on 21/8/10 at 08:58 AM Reply With Quote
taken the bike down sensor off and double checked the position and its correct, arrow pointing up
locostbuyer83
posted on 21/8/10 at 09:14 AM Reply With Quote
ok speedo flickering problem went away once i double checked i had the engine > main loom plugs connected firmly.
ive done the 100phm resistor onto the grey wire on the ecu and sent it to +12v
to disable the clutch switch i've slit and sent the red/green and light green wires from the bike fuse box to earth
if any of this sounds wrong please say
fluidslvr
posted on 21/8/10 at 09:34 AM Reply With Quote
cut the red/green and light green wires from the ECU and earth... not the fuse box
HTH
http://mkmidi.blogspot.com
locostbuyer83
posted on 21/8/10 at 09:42 AM Reply With Quote
HTH
made that change, still no spark
any other thoughts?
