aka Keith
| posted on 18/1/11 at 10:17 AM |
zx9r question on plug order and effect on engine
I was mucking about at the weekend, and thought to replace the plugs on the zx9r. As I took of the HT to no4, you could hear the engine buck and
stutter. Putting the HT back on 4 and then removing 3 however was a different story with a little difference in engine sound.. Put back on HT to 3,
and remove 2 and the same again, put back the HT to 2 and remove the HT to plug 1 and again buck and splutter.
Is the discrepancy between the results of removing the HT to the plugs normal? as I would have assumed that I would get the same reaction irrespective
of which plug had gone?
Craig
r1_pete
| posted on 18/1/11 at 10:21 AM |
Yes, it sounds as though the fueling isn't balanced evenly between all 4 cylinders, some working harder than the others.
Whats the tickover like?
aka Keith
| posted on 18/1/11 at 10:31 AM |
Pete, the tickover seems okay at just below 1200rpm (which I think is within limits). Sounds like I may need to invest in a set of carb balancers and
get the spanners out.
[Edited on 18/1/11 by aka Keith]
jossey
| posted on 18/1/11 at 11:00 AM |
which reminds me pete....
ill see you next week if ye about.
dave
David Johnson
