gavinpurvis
| posted on 18/2/11 at 11:14 PM |
hazard lights
evening
to wire hazards into a bec can you just use a hazard switch and connect to the indicator relay, or do you need to use a separate flasher unit?
thanks
omega0684
| posted on 19/2/11 at 09:40 AM |
i have used a seperate flasher unit on mine
look here on the right hand side top drawing
the diagram is on page 49
Thurbs
| posted on 19/2/11 at 10:50 AM |
I used a separate relay just makes things a bit simpler, is possible with one though I just had the indicators making the hazard warning light flash
and couldn't be bothered to work out why so just chucked a flasher relay I had laying around.
bi22le
| posted on 19/2/11 at 11:45 AM |
You should really use a separate flasher unit. With Diodes it can be done though
Please read my ring story:
