Author: Subject: R1 clutch lever movement
JekRankin
posted on 28/2/11 at 09:35 AM Reply With Quote
I've recently fitted a stiffer diaphragm spring to my 03 R1, but I'm concered that I may not have put things back together correctly.
With the torsional spring on the clutch lever un hooked, the lever rotates freely back and forth by about 30 degrees or so.
I must admit to having little understanding of how a bike clutch works, but I would have expected the lever to have at least some resistance to movement even without the spring fitted.
Does this sound right? Sorry for the very basic question, but I've reassembled the lever arm and clutch cover a few times and can't see what I've done wrong.
Jek
MK9R
posted on 28/2/11 at 09:42 AM Reply With Quote
No that's fine, mine is the same, other than the coil spring there is no resitance until fork engages with clutch mech
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
JekRankin
posted on 28/2/11 at 09:47 AM Reply With Quote
Brilliant, thanks.
