coyoteboy
| posted on 20/10/11 at 08:52 PM |
Early R1 throttle bodies
The early (01/02) r1 ITB are injection (I can see injectors) but also have large black caps/spring arrangements which I associate with carbs.
Considering using a set on a 2.1 litre car engine but don't want to buy these if they're essentially part carb part injection - can anyone
throw any knowledge at me?
yamapinto
| posted on 20/10/11 at 09:18 PM |
They are throttle bodies the slider arangment works well to smooth out hard throttle acceleration if you are buying some to fit to a pinto I have a
set on a custom manifold correctly spaced with all linkages and using 8 injectors should you to be so bold
Yazza54
| posted on 20/10/11 at 09:59 PM |
The slides can be removed by fitting slide stops. Well it doesn't remove them but holds them open. You shouldn't really need the slides on
a car TB conversion.
I'm unhappy cos I eat and I eat cos I'm unhappy
coyoteboy
| posted on 21/10/11 at 12:49 AM |
If my plans pull off I'll need 2 sets and I'll end up having to make my own manifolds I'm afraid. They seem like reasonable V8 ITBs.
Balancing them may get fun.
afj
| posted on 21/10/11 at 07:11 AM |
02 / 03 ones are what you want 2001 will be just carbs not the TB with cv slides type things
eerrrrrrrrrrrrrrrr
coyoteboy
| posted on 21/10/11 at 08:21 PM |
Much appreciated! We'll see if the finances stretch to 2 sets after I find a clutch and gearbox
