gingerprince
| posted on 23/10/11 at 03:35 PM |
893/919cc blade compatibility
Does anyone know if a 919 blade lump will run off 893 carbs and wiring, or are there subtle differences? Also is the mounting identical? I know the
gear shift is reversed.
mark chandler
| posted on 23/10/11 at 03:51 PM |
I swapped all mine straight across when the 893 threw a con rod and put in a 919, as you note the only noticable thing is gears are now back to
front.
Also the bolt holes by the chain cover are a bit larger, I had a little bracket for speedo pickup.
Regards Mark
[Edited on 23/10/11 by mark chandler]
Dangle_kt
| posted on 23/10/11 at 05:37 PM |
919 has TPS, 893 doesn't. Think it runs though.
mark chandler
| posted on 23/10/11 at 05:44 PM |
893 ECU will not care about TPS, going the other way may be an issue.
You also need to swap over the thermostat housing as the 919 will have a remote thermostat down by the starter motor.
Benzo
| posted on 23/10/11 at 11:44 PM |
oh really? i didnt know that, althought i have the thermostat removed in mine..
I ran a 919 on an 893 ecu also with no problems.. then i fitted the 919 ecu later.. pink wire & resistor is the only difference. I have wiring
break down at home if you want me to post it?
Other than that there is no difference.. for the gearbox reverse its a good excuse to put some paddles and a cable shift in too
