mitch46
| posted on 4/12/11 at 11:01 PM |
fuel pump running consantly
hi swapped from a carbed blade to a injected blackbird got it running today and runs fine,
just a quick question should the fuel pump run consantly or cut out when up to pressure when ignition on?
i know on bikes ive been around mainly cbr 600 and 1000 they run for a couple of seconds the cut out till you fire them up, will i cause me any probs
with it running constant?
all i've done is connect the new bike pump to the old original wiring that was there for the carbed pump
sorry just that wiring is not a strong point of mine lol
cheers
mitch
[Edited on 4/12/11 by mitch46]
matt_gsxr
| posted on 4/12/11 at 11:10 PM |
Continually is normal (whilst engine running).
If they are the same as the in-tank gsxr ones then the pump runs all the time and pressure is controlled by a spring loaded regulator.
The carbed pumps are actually a bit cleverer (to my mind) as they don't waste all that electricity.
adithorp
| posted on 4/12/11 at 11:28 PM |
Normally the pump will run for a couple of seconds when you switch the ignition on, then stop untill you start the engine. It then runs continually.
Thats controled by the fuel pump relay. If you've simply conected to your old wiring it will run constantly with the ignition on.
http://jpsc.org.uk/forum/
loggyboy
| posted on 4/12/11 at 11:36 PM |
Yeah, some prime, (you get that spit second of whine as you turn the ignition) others just pump when the igniton is acctually turned over (My c20xe
was like that). Shouldn't run constantly if the engine isnt running. (not that it will cause any running problems, will just waste electricity!)
Dusty
| posted on 4/12/11 at 11:49 PM |
As above and usually from a relay that is further controlled/operated by the ECU.
MikeRJ
| posted on 5/12/11 at 09:39 AM |
On a bike it doesn't make any difference, since any power you don't draw from the alternator is converted to heat anyway, as the
regulators are of the shunt type.
