Author: Subject: R1 5VY wiring
bigfoot4616
posted on 28/12/11 at 08:10 PM Reply With Quote
R1 5VY wiring
finally got back onto the wiring today and have a connector i'm not sure what its for. can't find it in the wiring diagrams
the one on the right
its a 6 pin connector with
red/white Ign live
red/green backup fuse
yellow/blue ecu and dash/headlight loom con.
light green dash/headlight loom con.
black earth
black unknown 2 pin plug on left( the other black from that plug connects to the backup fuse via the red/green above)
i know the red/black and red/white stop switch wires need shorting and powering from the ignition switch. should that be done via the FIA cut off switch?
thanks
A1
posted on 28/12/11 at 08:53 PM Reply With Quote
just off the top of my head, the one on the left is the oil level sensor.the other one I cant remember. might be coils/injectors...
If youre still stuck i can look tomorrow and let you know.
bigfoot4616
posted on 28/12/11 at 10:03 PM Reply With Quote
not to bothered about the left one but don't think its the oil level. already got that accounted for.
definatly not coils or injectors, they are all wired up
