Nurburg2006
| posted on 5/5/12 at 05:26 PM |
bec diff ratio
hi guys what diff ratio should I use for my blade engine? any help would be good its a mk2 escort rear axle
[Edited on 5/5/12 by Nurburg2006]
twybrow
| posted on 5/5/12 at 05:36 PM |
3.54 would be my ratio of choice for a BEC... If you do a search, there is a gear calculator spreadsheet that lets you work out the speed in each gear
with any given wheel/tyre/axle combo...
mark chandler
| posted on 5/5/12 at 05:53 PM |
Standard 893- 919 blade will hit max revs ~13,000 at max speed ~125mph with a 3.65 diff running 185/60/13 tyres
A lower ratio would be better for the road.
Regards Mark
MK9R
| posted on 5/5/12 at 06:39 PM |
For live axle the 3:5.4 is perfect for the blade
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
ian locostzx9rc2
| posted on 5/5/12 at 07:03 PM |
3.54 the only diff to use max speed will be 120 ish dependent of tyre size
