gixermark
posted on 14/5/12 at 10:53 AM |
MSA master switch issue ?
another snag i have......
after a few laps my dash display disapears... and with it my transponder (direct wired) which seems to upset the officials somewhat...
i had the transponder wired into the ignition switch initially.... but then gave it its own feed direct off a spare circuit on the fuse box.... and
same thing happened. I also replaced the fuse box (easy thing to try)
am now thinking it may be the master switch ? i've never had the pleasure to investigate the wiring of a master switch, but i guess it must
connect to all positive feeds on the carm and maybe the feeds going to the 'accessories' end of things is a bit tempermental ? although
not sure why it works every time in the paddock/garage... and only fails after a number of laps.
thankfully the engine keeps singing - its got an elec water pump/fuel pump... injectors etc so it keeps doing its thing while the rest of the car goes
to sleep..
any ideas ??
HowardB
posted on 14/5/12 at 11:54 AM |
if as I suspect the master switch should kill everything, then the fact that the engine still works suggests that the fault lies elsewhere. My initial
thoughts are that you have a vibration/heat induced earth fault. An easy test would be to run a separate wire from the battery neg to the
dash/transponder and see if this fixes it?
hth
Howard
gixermark
posted on 14/5/12 at 12:44 PM |
good point........
the heat one sort of makes more sense... although it could just be a bad connection somewhere as you say.
possibly one step in the right direction is to give the transponder a new (direct) earth feed next time out, and see if it at least behaves... if the
dash still goes out - them we most likely just need to feed it a new earth too.....
procomp
posted on 14/5/12 at 06:04 PM |
Hi
Mark the switches are notoriously crap. The main problem is that the two brass contact inside eventually make less pressure as a contact and results
in various problems. A quick bodge fix / conformation off the switch or problem else where is to increase the pressure on the contacts by sticking a
packer ( 2mm thick washer ) in the hole then the key, that significantly increases the pressure. If that cures the problem replace the switch as the
brass terminals are buggered.
If problem persists obviously problem else where.
Cheers Matt
gixermark
posted on 14/5/12 at 07:15 PM |
fine suggestion Matt - I will try that next time... I woudl have thought if the master key was a bit dodgy, then all circuits would fail - but like
you say, they ain;t the most reliable bits of kit - and thats definately worth a punt
[Edited on 14/5/12 by gixermark]
