b3ngy
| posted on 5/6/12 at 08:36 PM |
changing gear selection direction
Hi everyone,
The gears on my busa powered Indy are set up so that you pull to select first then push to go up the gears. I wanted to change the setup so that you
push to select first and then pull to go up the gears.
I know its possible to change this and I have a couple ideas of my own but was wondering how other people have done it (in case I've overlooked
something) or if there's a set in stone way of doing it.
Ideas/pictures please
Thanks, Ben
daryl
| posted on 5/6/12 at 09:00 PM |
Where the gear shift stick is on your engine am sure if you take it off rotate it 180 then put it back on a think that will work for you
maccmike
| posted on 5/6/12 at 09:02 PM |
Im the same, currently have two linkages connected by a bell crank. I plan to fix both links together and remove the bell crank.
b3ngy
| posted on 5/6/12 at 09:13 PM |
Surely you need to keep the bell crank in order to keep the 90degree change of direction in the linkage?
maccmike
| posted on 5/6/12 at 09:27 PM |
no, if I had a picture you'd understand. A straight bar with a dog leg would allow me to go forward for first and back to go up the box.
b3ngy
| posted on 7/6/12 at 09:21 PM |
I think I understand what your saying (although a picture would help)
Daryl, I think thats the easiest solution, as I hadn't thought of that, thanks for the help
daryl
| posted on 8/6/12 at 05:49 PM |
Well a do hope it works for you m8 let me know how you get on
b3ngy
| posted on 8/6/12 at 06:08 PM |
Will do however might not be for a few a weeks as car is in bits! Back in to the garage i go!
daryl
| posted on 10/6/12 at 01:23 AM |
Tell me about it m8 been about 2 years for me out soon. Been getting my first house so been spending cash on that but it's been to long now so
time for it to come out to play
