Jon Ison
| posted on 15/1/13 at 07:31 PM |
Busa, gen 2 crank into gen 1 motor ?
Anyone done this mod, takes motor to 1340 ?
KJK
| posted on 15/1/13 at 08:18 PM |
gen 2 crank
You need to u2 u to cosmick he did this to his engine so it can be done
cosmick
| posted on 18/1/13 at 05:21 PM |
1340 Gen 2 crank fitting.
Hi Jon,
Yes I have done this conversion and it has been running successfully throughout 2012. There are 2 ways of doing this, one is to use the new crank with
the existing con rods. This will require a 1mm spacer Cometic gasket to fit underneath the cylinder. The advantage of this is you keep your pistons
and rings and conrods simply connecting to the GEN 2 crank. You will also need to buy adjustable cam wheels for you camshafts to adjust the timing of
the cams due to the increased height of the head.
Method 2 is to use GEN 2 crank, conrods and pistons. These con rods are shorter with a different compression height and use a different sized gudgeon
pin. This way does not require a 1mm spacer and also does not need adjustable sprockets as the cam shaft heights remain the same.
I used method 1 and put the cam timing to standard. The net result on a dyno was 15 hp increase and 6ft/lbs of torque increase. However the torque
curve is impressively flat and the car makes 75ft/lbs at just 3000 rpm with a maximum 97ft/lbs at 7800rpm. Bearing in mind that most 1000cc engines
make 75ft/lbs peak torque and much higher up the rev range, i was pleased with this.
I use my car for a mix of Road and Track days. The reliability has been second to none and on track it does get used. If you need any more info, just
ask.
If it can't be fixed with a hammer then its probably an electrical problem.
Jon Ison
| posted on 15/2/13 at 06:24 PM |
Update.......
Brand spanking new gen 2 crank going in (thanks to powertec removing them for there mega bucks radical engine builds) 2 pistons looking tired so need
a new set, if buying new pistons guess they need to grow a bit so better bore the block, Will report back early next month when it's run in and
been re mapped.
daniel mason
| posted on 15/2/13 at 06:44 PM |
theres a gen 2 crank on pistonheads for sale,its been up for weeks!
Jon Ison
| posted on 15/2/13 at 07:22 PM |
Not looked, how much ? Brand new rules out worrying about it's history though, wasn't expensive either.
daniel mason
| posted on 15/2/13 at 07:38 PM |
its brand new and £300. in kit car section classifieds
Jon Ison
| posted on 15/2/13 at 07:58 PM |
Great price for a new crank, that's what I paid plus vat though unfortunately. Suzuki want £800 plus.
daniel mason
| posted on 15/2/13 at 08:12 PM |
he said he paid £900. i was thinking about it but have spent too much already. good luck!
:{THC}:YosamiteSam
| posted on 17/2/13 at 04:21 PM |
quote: Originally posted by Jon Ison
Update.......
been re mapped.
you replace piston rings on busa? id heard they have a ceramic coating on that makes you buy new block?
or do you simply rebore bigger - new pistons - but then again ceramic coating issues?
Jon Ison
| posted on 18/2/13 at 01:08 PM |
Re bore and re coat, £600.
Ciavatta
| posted on 17/3/13 at 11:02 PM |
quote: Originally posted by cosmick
... You will also need to buy adjustable cam wheels for you camshafts to adjust the timing of the cams due to the increased height of the
head.
Hello Cosmick
I did the same mod as you, but never heard about the quoted part.
Can you please give me more info about that?
Now the car is completely stripped, awaiting for a new chassis, but when it was still running I noticed the power delivery was a bit too rich in the
lower end, I thought the engine needed a remap, as I was using a powercommander... But at this point I'm starting to think the issue was with
the timing. It sounds right to you?
Just for info, I bought a new gen2 crank from powertech from a really good price (+1 thanks to them removing from new busas ) and new gen2 main
bearings from Suzuki.
cheers
cosmick
| posted on 18/3/13 at 09:00 PM |
Hi Ciavatta,
Check out A.P.E Hayabusa adjustable cam sprockets. These are not Suzuki parts and they are designed to replace the standard sprocket. You need to
press off the original sprocket and replace them with the adjustable type. If you need more information drop me a U2U.
Cheers, cosmick
Jon Ison
| posted on 6/4/13 at 06:01 PM |
Dropped engine back in today, started 1st push of button, all 1441cc's of her..........
Jon Ison
| posted on 11/5/13 at 06:08 PM |
Further update, been on rollers this morning.
Just slightly more than max torque available prior to engine rebuild now on tap at 60% throttle.
Rear wheel bhp up by 28.
Same dyno.
sam919
| posted on 10/11/13 at 01:37 PM |
Some good info there, so its a good way of getting an extra 20 ish bhp and more torque? Ive been reading some US forum and its all a minefield with
regards to the best way to do it.
I have the engine so im off to start purschasing the bits for the re-build,.......if its worth it, claims of 7hp is a bit worrying !
Any further feedback on what been done?
Ciavatta
| posted on 22/11/13 at 03:26 PM |
I think it is woth doing if you've to change the crank due to a failed journal or somethink like that. If you want to swap the cranks just for
HP, I think you would place the money on different mods. (Head porting/cams/Bigger Pistons or Supercharging)
[Edited on 22/11/13 by Ciavatta]
sam919
| posted on 26/11/13 at 09:35 PM |
Its a pretty cost effective mod if you can get the parts cheapish from RPE, crank anyway,.......for the figures quoted. Cams, SC etc you start getting
into big money.
daniel mason
| posted on 26/11/13 at 10:06 PM |
id say by building a caterham busa you'll be spending mega bucks anyway! ask me how i found that out
[Edited on 26/11/13 by daniel mason]
sam919
| posted on 26/11/13 at 10:18 PM |
Aye thats right, its still a better shout from the three rebuilds at 5 grand a pop on an already 14 grand install! in 8 hours..........300bhp
Duratecs, never again haha
daniel mason
| posted on 26/11/13 at 10:26 PM |
speak to darren luke (DSL on the forums) he always has busa bits as he has a caterham busa with 1585 motor
sam919
| posted on 27/11/13 at 09:08 AM |
OK cheers, I recognise that name from pH forum and he's chatted quite a bit about his car on there. I've put the engine up for sale now
anyway to go down a different route!
Ciavatta
| posted on 27/11/13 at 11:21 AM |
Totally agree, I bought a bargain Gen2 crank from RPE indeed!
But I have to change it anyway, due to a worn crank journal.
If you put into the equation also a pair of adjustable cam sprockets, new gaskets, spacer plate, and rebuild/degreeing labour... You're going to
spend big money for not so much HP gain, IMO.
40 more cc's doesn't make a big difference to me, I think the point to swap for a Gen2 crank is the uprated oil routing on the mains, not
the HP figure.
With a grand or so, and an healty engine, it would be more cost effective another route, like ported head+new cams, as it seems this is the area where
you can find most of the hidden horses. Or maybe a stroker kit, if you're looking for a real step in displacement.
Just my 2 cents (Eurocents actually, so a bit less than "the real" 20 pence )
sam919
| posted on 27/11/13 at 05:03 PM |
Good points, but with the fugures that have been quoted above you'd struggle to get near for the price, thats why im interested in the 15bhp and
6lbft claims for this rise in hp for swapping the crank and using the following components?
Crank - 260 RPE on Ebay
Sprockets - 160 Again RPE
Cometic spacer - 50
Gasket set - 180 (full set)
Total - 650
A set of decent cams - 750 cheaper if exchange
Head Work - ???
Labour is going to come into each equation if your not doing it yourself, but if your getting the crank swapped its a pretty simple job i would have
thought 250-300 quid/ days work max, which brings you to a grand that youve said
I agree top end work would be a way to get more power but RPE quoted me 3 grand for this?! for 195bhp
I'd like to hear about the people that have done this to get a true appreciation for the mod.
sam919
| posted on 27/11/13 at 05:05 PM |
Cometic spacer - 50
Total - 650
A set of decent cams - 750, cheaper if exchange (about 280 odd quid)
Head Work - ???
