Sloan85
| posted on 7/4/13 at 10:48 AM |
Help! I cant get the propshaft off the sprocket adapter!!
I need to take the sprocket adapter off as there is too much movement on the splined shaft (I think I need to add a washer). I have undone the 4no
bolts holding the propshaft to the sprocket adapter but the two are stuck together. How can I separate them? Tried WD40 and hitting the edge of the
propshaft with a hammer and screwdriver but the two just wont separate.
Any suggestions??
Cheers!!
Sloan85
| posted on 7/4/13 at 10:58 AM |
Sorted it.
If in doubt, use a bigger hammer!!
NigeEss
| posted on 7/4/13 at 11:00 AM |
I'd be looking at a very thin chisel, or a wallpaper scraper hammered into the join.
omega 24 v6
| posted on 7/4/13 at 12:22 PM |
While its off drill and tap a couple of 6mm holes. Then you can then screw bolts into them in the future to seperate the two halves.
britishtrident
| posted on 7/4/13 at 12:33 PM |
Put it in a low gear and push the car rocking it backwards and forwards.
[/I]
| posted on 7/4/13 at 03:04 PM |
Put the brakes on and start the engine
:{THC}:YosamiteSam
| posted on 7/4/13 at 05:22 PM |
rubber mallet
or hb on - rock the car in gear?
