T66
posted on 31/7/13 at 01:19 PM |
Joining two radiators together - How?
The engine radiator is mounted ok, and Im looking to mount the chargecooler radiator in front of it -
whats the best product to give me a simple solution, are the fan mounting kits up to the job ? Or could it be banded ?
thanks guys
Ivan
posted on 31/7/13 at 01:28 PM |
Bend some brackets to attach to them top ones and hang it off them?
T66
posted on 31/7/13 at 01:57 PM |
Alloy strap maybe with riveted ends?
richardm6994
posted on 31/7/13 at 02:22 PM |
thats the problem nowaday's! So many people's first thoughts are for an off-the-self bought item instead of rolling up their sleeves and
making something!!
For me, most of the pleasure and pride comes from the bits I've made!!
[Edited on 31/7/13 by richardm6994]
jps
posted on 31/7/13 at 02:31 PM |
Isn't having one directly in front of the other going to b@gger up the airflow - unless you get them VERY carefully lined up?
pewe
posted on 31/7/13 at 02:41 PM |
Kenlowe fitting kit is simply four foam pads between the rads and mushroom zip-ties to hold the rads together.
Seems to have lasted well on my tin-top over years.
Google electric fan mounting kit or similar.
HTH.
Cheers, Pewe10
MikeRJ vv the auto transmission cooler on the tin top has been mounted like that for about 11 years without any damage to either core. Maybe if
it's mounted incorrectly I.e loose by not drawing the cable ties tight it could cause damage. Chaqun a son goo.....
[Edited on 31/7/13 by pewe]
T66
posted on 31/7/13 at 03:16 PM |
Im lead to believe as long as they are close together, no gap then it will be fine, it will get an alloy duct either side to feed it.
Quite like the idea of making everything, only problem with that is I know nowt....
Kenlowe fan kit it is, and relax !
MikeRJ
No way would I use a fan mounting kit, they eventually damage the radiator core even with the low weight of the fan, hanging another radiator off a
radiator core would not end well IMO.
I agree with Coozer, just make some extended brackets to share the mounting points of the main radiator.
T66
posted on 31/7/13 at 03:26 PM |
Point taken Mike , the rad is a lot heavier than a fan, and the engine radiator is a special one, which would be costly to repair.
Yippee another job
tomgregory2000
posted on 31/7/13 at 07:30 PM |
Do they have to be mounted in front of each other can you mount one above the other?
T66
posted on 1/8/13 at 09:08 AM |
There's not the the room. The rad lays at about 45deg taking the air from front grill and ducts out through the bonnet. I need to bracket it
infront of the engine rad....
Cheers.
