kj
| posted on 16/6/14 at 05:45 PM |
sump baffle plate
Fitted and now leaks oil torqued up two gaskets. Any ideas its flat, thinking of taking it out as it never leaked before.
Think about it, think about it again and then do it.
teegray19
| posted on 16/6/14 at 05:50 PM |
Are you using plenty of gasket paste to put it back on with? And a decent gasket?
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
snapper
| posted on 16/6/14 at 05:57 PM |
What I did with a crank scraper was to use Hylomar and seal it to the block
Then seal the gasket to the sump setting overnight
When set I smear a thin layer over the gasket and put the bolts in lightly, leave over night
Remove bolts one by one the next day, smear thread and bolt face with sealant then torque up in designated order
Bolts are usualy tightened to only a few Ft/Lbs
I eat to survive
I drink to forget
kj
| posted on 16/6/14 at 07:50 PM |
A bit gasket paste fully torqued up. May need to strip back and put it on thick.
ashg
| posted on 17/6/14 at 11:24 AM |
Chop the outer bit off and weld it in
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
kj
| posted on 17/6/14 at 12:19 PM |
A bit extreme
