b3ngy
| posted on 11/7/14 at 06:20 PM |
hayabusa speed sensor orientation
I'm trying to set up the stock busa speed sensor on the front propshaft bolts. I was wondering if the bolts have to pass the sensor like the
stock pick up would on the actual bike or if I can point the end of the sensor at the bolt heads?? Would it still pick up a signal in this
orientation??
Sloan85
| posted on 11/7/14 at 09:29 PM |
I would have thought this would work. I think the sensor just detects when something metal passes it so as long as it is positioned close enough, it
shouldn't matter.
http://mkindygsxr.blogspot.co.uk
b3ngy
| posted on 11/7/14 at 09:42 PM |
Think I will give it go, space is so tight in that area that mounting it like that will make things easier.
b3ngy
| posted on 24/7/14 at 08:56 PM |
^^^this doesn't work. the sensor should be position as it is on the bike.
