Author: Subject: oil pressure
aliwizard
posted on 30/5/16 at 03:45 PM Reply With Quote
oil pressure
hi could anyone give me there advice on a problem with the oil pressure on my zzr1100 motor,i have been building the car for years but not far off iva ,the oil pressure gauge is a racetec item ,when the throttle is blipped the oil pressure gauge is more like a rev counter sweeping up and dropping down as the revs fall ,I had been taking the pressure reading out of the sump ,but spoke to carl at extreme engines and was told to take my flexible out of the 17 mm nut just below the ignition cover apparently this is the main oil gallery ,this has been done now ,I have more pressure than ever and still have a rev counter for a pressure gauge ,any ideas would be much appreciated
Andy B
posted on 30/5/16 at 03:57 PM Reply With Quote
What is the operating range and f the gauge you are using?
aliwizard
posted on 30/5/16 at 05:26 PM Reply With Quote
oil
hi Andy I think it should be about 24 to 44 psi at 4000 revs it is a racetec gauge new but been in for a few years
adithorp
posted on 30/5/16 at 05:30 PM Reply With Quote
Think Andy meant whats the range of the guage; 0-?psi
Also you say it's going up/down with the revs but what readings are you getting?
How were you getting any pressure reading in the sump?
http://jpsc.org.uk/forum/
aliwizard
posted on 30/5/16 at 05:45 PM Reply With Quote
oil
yes sorry I see what you mean, gauge range is 0 to 100 psi racetech
adithorp
posted on 30/5/16 at 06:13 PM Reply With Quote
Not familiar with the zzr1100 but the R1 oil pressure can vary from 5-10psi at idle to 80-90psi at revs (more when cold) so with a 0-100psi gauge it would look like a rev counter. Movement wouldn't look as extreme with a 0-150 scale, but would still vary a lot.
Is it an electric or capillary gauge?
aliwizard
posted on 30/5/16 at 07:04 PM Reply With Quote
oil
hi ,it is a capillary
adithorp
posted on 30/5/16 at 07:32 PM Reply With Quote
...and the reading you're getting at 4000rpm is? Also what does it read at idle and high revs?
aliwizard
posted on 30/5/16 at 08:02 PM Reply With Quote
oil
I will have to get back to you on that I will have to run the engine and have a look
aliwizard
posted on 31/5/16 at 07:06 PM Reply With Quote
oil pressure
hi all and adithorp right, I ran the engine up to temp ,at idle about 11 psi ,at 4000 rpm 54 psi should be between 23 to 45 psi ,at 5000 rpm 60 psi it holds these pressures ,the pressure does not drop away ,its not been jetted yet so struggles after 5000 6000 rpm, I have done away with the mechanical water pump and have a electric one ,note shore if this would make a difference to pressure probably not , but there is still this rev counter effect on the gauge ,cheers nick
adithorp
posted on 31/5/16 at 08:01 PM Reply With Quote
All sounds normal to me. The reading are slightly higher than you're expecting but just running the engine (coolant) up to temp', won't get the oil truly hot. As it's a capillary gauge, then it can't be wired incorrectly or be affected by interference or voltage variation or mismatch of sensor/gauge like an electric one. If by "rev counter effect" you mean the pressure goes up/down with the revs... well thats what it does. The pressure variation in a bike engine is greater than in a car engine so can be unsettling.
I'm still confused as to how you were getting a "pressure reading out of the sump" previously.
daviep
posted on 31/5/16 at 09:33 PM Reply With Quote
ZZR sump has galleries cast in to it, oil pressure switch is fitted to the sump when it's in the bike.
Davie
“A truly great library contains something in it to offend everyone.”
adithorp
posted on 31/5/16 at 09:48 PM Reply With Quote
Ahhh!
aliwizard
posted on 1/6/16 at 06:43 PM Reply With Quote
oil
thanks for the replies , yes sorry should of said I came out of the oil pressure switch outlet I thought this would be ok for the gauge but as I said carl at extreme engines said the 17 mm plug in the main oil gallery was the place to come out of , I have been told to check the oil pressure relief valve ,I am not shore the effects would be of a valve stuck open and stuck closed ,I think I am right in saying that to much oil pressure is as bad as not enough ,I may have a look at the relief valve as I may modify the sump as they sit very low on the zzr,i just want to be clear on this problem cheers nick
aliwizard
posted on 1/6/16 at 06:57 PM Reply With Quote
oil
hi guys how do the hell do I put a picture on here lol
