Digimon
posted on 15/8/16 at 03:29 PM |
2000 R1 clutch problem
Hi guys,
I have been searching the web trying to find some info on a problem I had yesterday with my clutch but no luck
The clutch pedal got stuck down at a roundabout after driving the car quite hard, after a taps the pedal came back but I've now got a whoring /
whining noise when pulling away
I'm going to remove the clutch tonight to see what it looks like but the clutch doesn't slip and it did get me home ok
Has anyone experienced this problem before or know what it might be?
The clutch is about 4 years old with two diaphragm springs
Minicooper
posted on 15/8/16 at 04:30 PM |
I reckon you have over thrown the clutch, this can happen because there is normally no physical way of stopping this in bike engine car conversions
and is often over looked.
CosKev3
posted on 15/8/16 at 05:56 PM |
Yeah pretty sure you can make the spring go inside out if you have too much leverage on it.
Have you got a pedal stop fitted?
adithorp
posted on 15/8/16 at 06:03 PM |
Sounds like it must have just got to the tipping point of flipping inside out. If it had gone further it wouldn't have come back on it's
own and would have required a strip down. Probably needs a pedal stop adjusting (or fitting). Alternative (given the noise) could be a problem
starting with the release bearing.
http://jpsc.org.uk/forum/
Digimon
posted on 15/8/16 at 07:41 PM |
Thanks for all the reply's guys
I haven't got a peddle stop at the moment but ill get working on fitting one asap
I have got a spare cover so if the noise continues ill try swapping that it over
Digimon
posted on 16/8/16 at 07:24 AM |
I've had a thought this morning, do you think I've made the diaphragm springs weak by over throwing them for so long?
adithorp
posted on 16/8/16 at 07:36 AM |
Lots of people have done it before and I've not heard of it affecting the spring before.
Digimon
posted on 16/8/16 at 07:39 AM |
That's alright then, hopefully they should be ok
