richard staniforth
| posted on 23/2/05 at 12:15 PM |
Fireblade H-VIX servo
Is the H-VIX servo (like the exup valve) needed on the fireblade. I don't have this with my engine and I was hoping to leave it off or just mod
the loom.
Anyone fitted the RRY without this servo.
[Edited on 24/2/05 by richard staniforth]
jacko
| posted on 24/2/05 at 06:52 PM |
rry
u2u tim windmill he is fitting a rry in his car
jacko
chunkielad
| posted on 24/2/05 at 09:02 PM |
The EXUP is removable if you upgrade the exhaust to a straight trough system. I assume your system is the same.
tim windmill
| posted on 25/2/05 at 10:59 AM |
it will run fine without the servo but if you are using the standard rry bike clocks it shows up as an engine fault if its not connected, you may be
able to sort the fault by altering the loom.
chunkielad
| posted on 25/2/05 at 01:20 PM |
I believe the Exup servo just needs 7.5Ohm resistor - can't see yours being much different. You can leave the servo in but not connect it to the
valve - just something else to go wrong then though
