andrew.carwithen
posted on 8/4/05 at 10:00 PM |
Prop Flange Adaptor
I'm going to need a prop flange adaptor for a blade engine. I've been advised that a spacer/washer should be used in conjunction with it
and the retaining bolt in order to allow the adaptor a few 'thou of end float on its shaft.
This apparently prevents the adaptor bolt working loose.
Have others used this method and does this spacer/washer come with the adaptor and, if so, which manufacturers supply the two?
(There's one on ebay at mo' but it doesn't come with a spacer - I asked him.)
Thanks,
Andy.
shortie
posted on 8/4/05 at 10:11 PM |
Andy,
I had some made up for me in a couple of different thicknesses by a local machine shop. You will need one unless the sprocket adapter is the exact
width of the sprocket spindle which is very unlikely as they vary alot.
Rich.
Bob C
posted on 8/4/05 at 11:41 PM |
I turned up my sprocket adaptor on the lathe & am pretty pleased with the result:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=propadapt.jpg
It clamps the original sprocket using the bolts in the "divots' to give positive location so the original sprocket is retained but does
not need to be machined in any way (handy 'cos it's hard as rock). Only the teeth of the sprocket are clamped, the rest seems to have a
plastic overcoat.
cheers
Bob
ChrisGamlin
posted on 9/4/05 at 01:26 PM |
IMHO it shouldnt have any end float on the flange, you want it bolted tight to the output shaft. The spacer is usually supplied to make sure this
happens as the retaining blt has been known to break if the flange can slide against it.
andrew.carwithen
posted on 12/4/05 at 09:09 PM |
What size threaded holes do the flanges of prop adaptors tend to have?
(there are ones listed regularly on ebay which have M8 threaded holes. Are these big enough to cope? - He can also supply 10.9 high tensile bolts to
go with them.)
Regards,
Andy.
ChrisGamlin
posted on 12/4/05 at 09:16 PM |
Yep, most prop flange bolts are M8 or a similar imperial size, usually fine thread though I think
Id go for high tensile ones just for belt n braces but regular 8.8 would probably be fine, I ended up used cap head (allen key) high tensile bolts
with a liberal coating of loctite
