Ferrino
posted on 30/6/05 at 11:21 PM |
Stripped Thread
While checking all the bolts on the engine covers (R1) were tightened up, I found that one of them (holding on the cover next to the cam-chain) had
stripped the ali thread in the block and was loose.
All of the threads have gone and I'm now wondering the best way of replacing it. It is an M6 bolt, and the hole is open at both ends:
Could I get away with replacing it with a 1/4" bolt (6.35mm) and would this bolt be able to cut it's own thread in the ali, or should I
really use a tap?
Cheers!
Glan Noye
posted on 30/6/05 at 11:37 PM |
http://www.helicoils.net/
Hellfire
posted on 30/6/05 at 11:56 PM |
Yippety yip - I'd go with that!
Danozeman
posted on 1/7/05 at 05:49 AM |
Id go with that too. Excellent things.
Dan
big_wasa
posted on 1/7/05 at 06:04 AM |
Yep I swear by them....
Where in the world are you ?
If locall I can help you out...Save spending £22 ish on a set...
What size is it ? M6?????
Ferrino
posted on 1/7/05 at 09:49 AM |
Hi - I'm in Oxford and yes it's an M6 thread.
It says on the website that the length of the inserts is twice the thread dia, so 12mm for an M6 - this is slightly to long for the depth of the
thread hole, as the cam-chain retainer is very close to the back of the thread hole - so can the inserts be filed/machined down to suit the required
length (about 9-10mm)?
Also, there is so little clearance at the back of the thread hole that I'd be worried about the swarf from drilling?
Thanks.
[Edited on 1/7/05 by Ferrino]
Surrey Dave
posted on 1/7/05 at 01:37 PM |
Is there enough room to just re -tap the hole 8mm and use either an 8mm bolt/stud or a special stud with 8mm one end 6mm the other , and glue it
in..........
Andy W
posted on 1/7/05 at 03:18 PM |
Not an ideal solution, but I've known people just use a 1/4" whitworth bolt. It does cut it's own thread. Maybe ok if you're
not planning on removing it to often. With helicoil's you can get different length inserts. Tapping drill for a 6mm helicoil is 6mm. So if the
threads stripped you should be able to use the helicoil without drilling. If you did use a drill there would be next to no swarf.
big_wasa
posted on 1/7/05 at 04:39 PM |
They can be had in many lenghts..The ones that I use are 1.5 x dia..But they are easy to cut down if you want shorter..
Ferrino
posted on 4/7/05 at 01:09 PM |
Thanks guys. I have run a 1/4" UNF tap through it and it looks like it will torque up just fine with this slightly thicker bolt. It's not
a cover I am likely to need to remove again, but if it does cause probs I will go the helicoil route.
